Which is more stable as a constant current source FET or Op-amp?
Discussion in 'The Projects Forum' started by nilesh.thakare, Sep 2, 2010.
  1. nilesh.thakare
    Sep 2, 2010
    hi,
    i am confused in selecting constant current source using FET or Op-amp.I just want to know that which would be more stable,because i am using that current source for excitation of the RTD sensor.Please help.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I suggest a linear regulator might be more stable than either, as well as easier to impliment.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Or even one of the 3 terminal adjustable current sources such as the LM334. If the adjustable current range meets your requirements.
  4. DickCappels
    Aug 21, 2008
    2,772
    669
    A well-designed op-amp current souce will be much more stabl than an FET connected as a constant current diode.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It depends on the lengths you are willing to go to. There are many things that affect stability of a circuit. After you eliminate the big influences you can go after the smaller ones. There is a point of diminishing returns where you expend enormous resources for minuscule improvements.
