Which has more effect on the strength of an iron core transformer?
Discussion in 'General Electronics Chat' started by Farlander, Dec 3, 2008.
  1. Farlander
    Thread Starter Active Member
    Oct 14, 2008
    158
    Will higher volts or amps increase the output of a step up coil?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    In my oppinion the current has most influence on the core.
    The voltage has most influence on the windings itself .
    (arcing at very high voltages , between the wires and between the wire and the core).
    Greetings,
    Bertus
  3. nomurphy
    Aug 8, 2005
    567
    12
    I'd go with the power amp, voltage is for pions.
  4. mik3
    Feb 4, 2008
    4,846
    63
    The title of the post is not really related to the question. Can you explain what you want to learn better?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Transformers handle power. Here is a link to our Ebook that explains how they work - http://www.allaboutcircuits.com/vol_2/chpt_9/2.html.
    Don't forget that Meiyers worked with 26 volts on the primary and a 3 to 1 step up, for 78 volts on the output. 20 KV and 100ma out of a step up is 2000 watts. That is 12 volts and 166 amps on the primary. Needs more than 30 ga wire.
    A literal reading of your topic would give recommendations for the alloying ingredients and heat treatment of the core.
