which driver can be used for IPW90R120C3 mosfet
Discussion in 'The Projects Forum' started by sid_392, Jun 5, 2013.
  1. sid_392
    Jun 5, 2013
    i need to find a driver Ic for IPW90R120C3.. can anyone please help me out.. it needs to be given gate source voltage of +/-20V...
  2. shortbus
    Sep 30, 2009
    4,088
    1,670
    Not enough information to give any help.
    Are you sure you want to use that mosfet? The "on" resistance is very high, this is given by the term, Rds(on), in the data sheet. Most mosfets have a much lower Rds, this in effect means less voltage drop in the mosfet and less heat.
    Give a schematic and more information about what your doing to get more help.
