What assumption are you making about the forward voltage drop of a conducting diode?Hi,
In this pic ...
Well you consider D1, D2 on and D3 off! Sorry it's wrong answer!D1 is on
D2 + D3 is off
Oops .....Recalculating
Nope D1 on, D2 + D3 off.
you got them right! But how? I spent an hour trying to find how but i couldn't. plz show me how you found that, thanksI get D2=off, D1 & D3 =on
But the more I look at it the less certain I am.
What about D2?Iterestingly enough my sim tells me that not all of them are ON. Sadly I don´t have the mental capability right now to figure out how to reliably come up with the result.
Edit: it seems there could be a bit of uncertainity coming from the assumed Vf of the diodes, which might turn D3 on as well. My sim seems to assume Vf of 0.56V at this sort of current with 1N4148 and states that D3 is off.
Well, you got it, but how?!D1 & D3 on............D2 off?
0VWhat assumption are you making about the forward voltage drop of a conducting diode?
0V or 0.6V or something else?
Sorry but the answer isn't correct!Ignore D2 and D3. Assume all diodes are perfect. Assume all diode's Vf are 0.6 V.
Loop current is 14.4 V / 30.2 K = 476.8 uA.
The node voltages are:
8.2K/12K = +5.49V. This is greater than 4.4 V, so D2 is off.
12K/10K = -0.232 V. This greater than -0.6 V, so D3 is off.
ak
This is NOT electrical puzzle this is example I found on google and I have been trying to solve it! And I shared it here so everyone can give me an idea how s/he got it. It's not my problem what do you think and how do you think! I asked question and I didn't write who is winner or loser YOU wrote it. And have fun with ignore button!Well isn't that special. You present an electrical puzzle and you leave out critical data. Then after several opinions are entered, you release the critical data at the same time you proclaim the winners and losers. Now where is that "Ignore" button I have been hearing about.
So, then Mesh analysis? I'll end up with 4 Loops? But how can I determine which one is on and which one is off?!Try making the circuit to better understand..
Thread starter | Similar threads | Forum | Replies | Date |
M | Different readings when testing a diode on-board and off-board | Test & Measurement | 4 | |
G | LTSpice solar panel, trouble with bypass diodes | PCB Layout , EDA & Simulations | 10 | |
A | Control or diodes? | General Electronics Chat | 25 | |
J | Diodes and Voltage Measurements | General Electronics Chat | 31 | |
J | Common Diodes | General Electronics Chat | 12 |
by Duane Benson
by Jake Hertz
by Jake Hertz
by Jake Hertz
