Which communication is best for underwater bots ?
Discussion in 'The Projects Forum' started by Abhinav Himanshu, Feb 19, 2016.
  1. Abhinav Himanshu
    Feb 18, 2016
    9
    I have been asked to design an underwater robot having pi and arduino in it . But since the bot is underwater so we are facing a problem on which communication board is best suited , we are designing the bot work at max 2 m depth , please suggest some communication board that we should use or anything else if possible . :):):D
  2. hp1729
    Nov 23, 2015
    2,105
    235
    Over what distance? Ultrasonic? Is cost a big factor? Sound (DTMF)? Is other wildlife going to be a problem (sharks, dolphins, whales)?
    Abhinav Himanshu likes this.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I guess the Navy likes sound for underwater communication. Not sure you have much bandwidth to work with however. You might be able to do 300 bits/sec with AFSK and a hydrophone.
  4. Picbuster
    Member
    Dec 2, 2013
    391
    53
    You are facing a world wide problem submerge 2mtr is not the problem it's the distance.
    Using low power ultra sonic does few hundred meter (15-20Khz depending salt/ temperature).
    However FSK modulating is a problem echo, Doppler and distortion plus a narrow band due to things mentioned above.
    All possible but it will take a lot of signal processing and I don't think that a standard board is available as yet.
  5. Abhinav Himanshu
    Feb 18, 2016
    9
    max 3 m distance between transmitter receiver (assume both in water ).As cheap as possible. Wildlife , not a problem.
  6. hp1729
    Nov 23, 2015
    2,105
    235
    Wires not allowed?
  7. Abhinav Himanshu
    Feb 18, 2016
    9
    ok , let say wires are allowed.Then which type of communication protocol is suitable , remember i am using raspberry pi , with bot control i even want to get video data from bot camera to my handheld controller , so what should i use.
  8. Externet
    Nov 29, 2005
    781
    58
