Which bulb lights up first?
Discussion in 'General Electronics Chat' started by RamaD, Jan 9, 2012.
  1. RamaD
    Thread Starter Active Member
    Dec 4, 2009
    254
    33
    Three bulbs are connected in series, and, a DC voltage is applied. Which bulb lights up first? Electrons move from -ve to positive, and, at speed of light, about a foot per ns.
    Simple question posed to me.
  2. Lundwall_Paul
    Oct 18, 2011
    222
    19
    Are they CFL bulbs in cold weather? If they are none will light.
  3. kubeek
    Sep 20, 2005
    4,686
    805
    A fraction of a ns will the ones closer to -ve "light up faster" or actually notice the current faster. If you take into account how long it takes for the filament to heat up, they start glowing at the same time.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    Actually the "effect" of electron movement is near the speed of light, but the electron movement is much slower. Since all of the electrons essentially move together along the series circuit, like boxcars on a train, all of the bulb filaments are exposed to the movement of electrons at the same time.
    http://amasci.com/miscon/speed.html
    Ken
    RamaD likes this.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
  6. BillB3857
    Feb 28, 2009
    2,402
    348
  7. PaulEE
    Member
    Dec 23, 2011
    423
    32
    I second that answer. I believe I saw this in an MIT opencourseware lecture video on circuits.
  8. w2aew
    Member
    Jan 3, 2012
    219
    64
    ...so the answer is - the bulb that has the highest cold filament resistance will likely light up first - because it will begin to dissipate the most power first, thus increasing the filament resistance more, thus beginning to starve the others of current. Of course, this assumes that all the filaments have the same thermal time constants, etc...
  9. kubeek
    Sep 20, 2005
    4,686
    805
    They are in series, so the hotter one starves others of voltage.
