Which bits should I solder on?
Discussion in 'General Electronics Chat' started by aaad2, Feb 17, 2014.
  1. aaad2
    May 30, 2012
    50
    Hi
    I need to solder off a sim slot connector component but there seems to been quite a lot of 'golden' bits on the component? do all of them need to be soldered on? if so, a soldering iron cannot reach or get close to them. I have a point headed soldering iron.
    As you can see from the pictures, I need to replace it somehow. If you look at the photo circuits, the component shows a few soldering bits(circled in red), do I unsoldering those bits first?
    I am replacing this component due to I have broken 4 of the 6 pins.
    All help appriciated.
    Thanks.
  2. aaad2
    May 30, 2012
    50
    If you would like me to upload a detailed verson of the new component, I will do so when it arrives in the post(in about one week time).
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    U need experience with those type to solder with a tip.
    But I do most of the time.
    Better tool is the hot gun.
    aaad2 likes this.
  4. aaad2
    May 30, 2012
    50
    I do not have a hot gun. Is it still possible to do this without it? If so, please help me :D
  5. aaad2
    May 30, 2012
    50
    Are there any alternatives to this?
  6. R!f@@
    Apr 2, 2009
    8,792
    771
    U would need de soldering braid to clean the PCB off excessive solder and some flux too.
    What I do is use flux to coat the braid and use a good gun heated up and suck all the solder from the board.
    I put the braid on the board and touch the braid with tip. Heat the PCB through the braid. ( solder area )
    Then put in the new socket and use fine ( eutectic solder ) solder with flux to solder and after that clean the board from excessive flux
    aaad2 likes this.
