Which acid is stronger?
Discussion in 'General Science' started by boks, Nov 19, 2008.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    1. The problem statement, all variables and given/known data
    2. The attempt at a solution
    Not I or V because here there's no increase in resonance stabilization.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Image did not come through on my computer.
    John
  3. boks
    Oct 10, 2008
    218
  4. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
  5. studiot
    Nov 9, 2007
    5,005
    515
    Well I make the compounds
    1) cyclohexanol
    2) phenol
    3) 4methylphenol or p-cresol
    4) dichlorophenol
    5) trichlorocyclohexanol
    Items 1 and 5 are cyclic alcohols which are generally less acidic than the 2,3,4 which are phenols. Ionisation is promoted in phenols compared to cyclo-alkanes/alcohols by the availability of resonance structures in phenols, which stabilise the ionised forms.
    Item 5 has three chlorine atoms which stabilise the ionised form, by induction, over the simpler item1
    But the phenols 2,3 and 4 will all be stronger.
    Of the phenols 3 is slightly weaker than 2 because the methyl group supplies electrons to the ring whilst 4 will be stronger because the two chlorines withdraw electrons.
    So 4 (3,4 dichlorophenol) is the strongest acid.
    You will have to look up the pKa values for yourself.
    Talking of resonance, I hope viewers do not confuse chemical resonance with mechanical/electrical resonance as discussed in other threads here. They are very different animals and bear no relation to each other.
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    "Congratualations. You are the 1,000,000 visitor. Click here to win"
    I don't see any chemistry question there, and I don't want to click through a bunch of advertising to get to one.
    John
  7. studiot
    Nov 9, 2007
    5,005
    515
    I captured the original.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
  9. mabsj2
    Member
    Apr 24, 2008
    22
    can't see anything
  10. gregdevid
    Member
    Feb 4, 2009
    18
    hi,
    I can't see and read some parts of your post.
