Where to fuse wall wart supply?
Discussion in 'General Electronics Chat' started by spinnaker, Dec 17, 2010.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,102
    1,190
    I built a wall wart power supply using the LM317 regulator.
    Actually it is not really a traditional wall wart but a old laptop supply.
    Normally PSUs are fused at the mains. I really don't have access to the main so where should I fuse it? At the input to my supply or at it''s output?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Post the circuit to get a good answer.
  3. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Here you go.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    The laptop power supply should be fused/have protection on both the main side and the low voltage output. And also be protected from say overheating. I would have placed fuses before all in pins on the voltage regulators. From the top of my head. I think the maximum current for your regulators are about 1.5 ampere. Remember that overheating may also be a problem regarding linear voltage regulators
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Agreed. But if you want additional protection put a fuse in right where the initial power comes in.
