Where to find buss fuses...
Discussion in 'General Electronics Chat' started by chipwitch, Mar 18, 2014.
  1. chipwitch
    Mar 29, 2013
    48
    Checked Mouser, digikey, ebay an mcmaster carr. I can't find the buss fuses for my DMM. They're the little ones, 3/4" long. 600V. I need two sizes. 2 and 10A. Mouser had 22 of the two amp. Zero 10 amp. Surely someone has to have them?
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    So its a "bussmann" fuse..
    now what series?
    It should say on the fuse..
  3. chipwitch
    Mar 29, 2013
    48
    "Buss" in the generic sense. There are no more markings than the voltage and current ratings.
  4. inwo
    Nov 7, 2013
    2,435
    315
    From the manufacturer maybe?
    Fluke is good about parts. I don't know about others.
    3/4" by ? dia.
    edit.
    Is only 600V the problem?
    5X20 10Amp seem common in other voltages.
  5. spinnaker
    Oct 29, 2009
    5,089
    1,185
  6. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
  7. chipwitch
    Mar 29, 2013
    48
    Max, those aren't rated for 600v.
    And "yes" @ inwo
    Manufacturer was a good suggestion. It's a UEI :(. (I really need to upgrade). My google search led to testequipmentdepot.com. They have them! $7 each! :eek: I might just take that $14 dollars and put it towards a used Fluke 45.
  8. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    What do you traditionally work on?
    If not working on 600 v power line equipment you should find no difference, the voltage only affects the sweep through and the open circuit danger.
    Apart from that they will work.
    Max.
  9. chipwitch
    Mar 29, 2013
    48
    Yes, I realize that.
  10. Zerotolerance
    Member
    Sep 18, 2011
    56
    10
    fuseco.com
  11. #12
    Nov 30, 2010
    16,704
    7,354
    I saw bins of 600V fuses at Grainger, the last time I was there.
    The deal is, you have to use a 600V fuse to qualify for a certain safety level certification.
    If I ever work 440V again, I'll go buy the right fuse.:rolleyes:
  12. Zerotolerance
    Member
    Sep 18, 2011
    56
    10
    I believe fluke is going with an 11A fuse instead of the 10A now. Just fyi. Don't quote me on that though.
  13. #12
    Nov 30, 2010
    16,704
    7,354
    Anything to make you buy the parts from the manufacturer.:mad:
    It's called the, "captive parts" program.
    Intentionally designing stuff to use parts that nobody else can provide.
  14. chipwitch
    Mar 29, 2013
    48
    LOL.. fuseco? Really? I don't need a pallet of them! They're a distributor. I already posted I've found them for $7 each. I thought that was high.
  15. chipwitch
    Mar 29, 2013
    48
    Yup... pretty much blows, #12.... (like the pun?)
    #12 likes this.
