Where to find a servo motor that moves like this?
Discussion in 'The Projects Forum' started by Duckinabearsuit, May 14, 2014.
  1. Duckinabearsuit
    May 14, 2014
    10
    Watch Video: http://youtu.be/Pxn9p_Yqg2U
    The point of the "robot arm" in this video is to continuously tap the screen of an iPhone in order to prevent the phone from turning off (like sleep mode), without actually having to touch the phone with your finger every minute or so. You can walk away from your phone, allowing the game to continue on. It's like setting up a macro for a computer game to keep it doing something, cheating at the game basically
    It is powered by USB and uses conductive foam on the tip of it to react with the touch screen of the iPhone.
    It uses no board, it is composed of what appears to be simply a servo motor and a usb cable.... where do I obtain a servo motor that moves like this?
  2. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    It should not require much effort for that, a heavy duty RC servo could be adapted to work.
    You would need to build or design the operator for it, however.
    * What is the point of double posting???
    Max.
  3. Duckinabearsuit
    May 14, 2014
    10
    Max,
    Thanks for your reply. Can you offer any guidance as to what the servo motor would be called that could do this? My apologies, I'm very new to this stuff...
    And you mentioned needing to build an operator for it? Like a board or controller?
    This operates fully from a USB power supply (5v, like plugged into a computer)
    I meant to delete the old post, though can't figure out how. I was worried it was a bit confusing to follow with all of my different speculations.
  4. Bernard
    Aug 7, 2008
    4,248
    423
    Just about any radio control model servo should work, 4 oz in or up. Maybe not the best solution but here are two servo controlls to give ideas:
    First gives two positions moving full speed between between positions, needs another 555 for desired period.
    Second gives variable speed between positions.
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    Wouldnt this be the simplest?
  6. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    And just give it a kick up the behind! :p
    Max.
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    it never needs batteries, just a glass of water once in a while.
    seriously, the guys here in the boiler house wanted a device to press a key on their computer once in a while to keep the screensaver from timing out. we just turned off the screensaver.
  8. mcgyvr
    Oct 15, 2009
    4,793
    976
    Albert the drinking bird is great.. I always liked that guy from science class.
  9. mcgyvr
    Oct 15, 2009
    4,793
    976
    You don't even need a servo.. a slow rpm continuous motor could be used too with the appropriate mechanical mechanism..
    shortbus likes this.
  10. shortbus
    Sep 30, 2009
    4,098
    1,697
    Suggested that in his other thread on this topic, a scotch yoke type mechanism gives the needed dwell.:D
  11. djsfantasi
    Apr 11, 2010
    2,914
    881
    A comma shaped cam on which the arm rides would work also.
  12. inwo
    Nov 7, 2013
    2,435
    315
  13. dwalsh62
    May 9, 2014
    I've seen this type of circuit before, from what I recall, it has a programmable USB chip, a NE-555 timer IC and an HI-8586 liner driver IC with a few discretes to run the servo all molded into the USB plastic as the SOP IC were extremely small, the driver code was simple, it would accept the position and speed and could be changed with a small config file.
  14. Bernard
    Aug 7, 2008
    4,248
    423
    I used a rotary solenoid to beat a tin can drum, simple mechanics.
  15. Duckinabearsuit
    May 14, 2014
    10
    How do I make the rotary solenoid move back and forth?
  16. Bernard
    Aug 7, 2008
    4,248
    423
    You hit it with a shot of current & it rotates about 45 deg, release current & spring returns it. On my test , used cap. discharge, but was trying for 10+ beats /sec. Available on different deg. of rotation & op. V.
  17. NFA Fabrication
    Member
    Aug 12, 2012
    104
    I don't fully understand how to manipulate capacitive touch screens, but is there a chance that this could be done in a solid state fashion? Is there anything that could be permanently be placed on the screen that could be given an electrical pulse from a simple 555 timer circuit that could simulate the touching? Before this video, I didn't know that there was a way to do it without human touch (Again, I know nothing about capacitive touch screens, just never needed to look into it). I always look for a Non-Moving/Solid state method as a solution to any project for reliability.
  18. Bernard
    Aug 7, 2008
    4,248
    423
    You could also use a push type solenoid for simple mounting.
  19. mcgyvr
    Oct 15, 2009
    4,793
    976
    Doesn't the iphone just have an optional setting to disable the screen timeout or set it to 30 minutes or something..
  20. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Excellent suggestion. :)
    Maybe a tiny strip of aluminium foil on the screen, and use a FET to connect it to a flat metal plate (or large foil patch) that the phone sits on?
    Surely someone out there has tried activating capacitive touch screens with electrical connections? It can't be that hard.
