Where to find a magnetic reed switch ?
Discussion in 'General Electronics Chat' started by Externet, Jan 21, 2015.
  1. Externet
    Thread Starter AAC Fanatic!
    Nov 29, 2005
    780
    58
    Do you know any vendor of a reed switch assembly (two parts) that will slide a magnet in the exterior of a housing actuating the reed switch inside the housing ?
    My depth-proof scuba flashlight had one of those as power switch. Cannot find something "trough-wall" like that, or do not know the proper term to search for one. The outer part is just a sliding magnet.
  2. #12
    Nov 30, 2010
    16,704
    7,354
    To make this easier to understand, I made a drawing for you.
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
  4. KJ6EAD
    Apr 30, 2011
    1,426
    364
  5. Externet
    Nov 29, 2005
    780
    58
    Thanks.
    #12; that is exactly the item. The magnet slides inside a holding channel that is secured to the exterior of a housing.
    Reed switches are available at many places including my parts bins but cannot find the magnet slider part.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  7. snav
    Aug 1, 2011
    100
    10
    Not sure about the shape of your light but reed switches are more sensitive in the parallel plane than end to end. If your light was round you could make a magnet from a 1x.125x.250 assy like the m13 from the previous link and two small plastic wire ties. You would probably have greater than 3/8" either side of center as active zone. FWIW
  8. cmartinez
    Jan 17, 2007
    3,698
    2,792
    You may also find this interesting. It's a microswitch with a reed switch inside, this helps keep the contacts completely sealed from dirt and moisture.
  9. Reloadron
    Jan 15, 2015
    1,055
    275
    Considering this goes back to 21 Jan don't know if you found a solution. Radio Shack if they are still open sells these things which is the magnet switch combination with both magnet and switch enclosed. Can't help but think I have also seen them in Lowes and Home Depot but looking online I can't seem to narrow my search in their sites to find them. Any good hardware store should also have them as they are popular for window and door alarm circuits. Then there is Amazon also.
    Ron
  10. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
