Where to Earth A Dimmer?
Discussion in 'The Projects Forum' started by Thazatoon, Mar 12, 2009.
  1. Thazatoon
    Feb 17, 2009
    12
    I've got a 240V AC wall dimmer I'm using in-line to control a free standing lamp. The dimmer is wired to a 3 core UK plug at one end and a 3 core UK trailing socket at the other. The dimmer itself has L1 L2 and C terminals. I've only used the L1 and C terminals with the live wire. The neutral wire and earth wires aren't connected anywhere in the dimmer. Is this safe?
    The dimmer has a metal plate fixed onto the dimming module but I haven't used it. Should I earth to this plate, or is it safe to leave the earth untouched and running directly from the plug to the trailing socket?
  2. Thazatoon
    Feb 17, 2009
    12
    Would really appreciate it if anyone could give me some pointers on this.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    If it's possible for the active (live) lead to dislodge and come into contact with the exposed (?) metal plate then one would be advised to earth the plate. Is there any provision for this such as a screw or stud termination point?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    You would be well advised to leave this work to a qualified electrician rather than doing it yourself.
    What dollar value can you place on your own or anyone else's life who might operate this unit?
  5. mik3
    Feb 4, 2008
    4,846
    63
    It would be safer to earth the metal part of the dimmer. However, if you can't do it make sure the insulation of the wires is fine as not to cause accidental touching of the live wire on the metal parts.
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I have no knowledge of electrical codes in the UK.
    Here on the left side of the pond we are required to ground all exposed metal parts.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It sounds to me like someone attempted to connect a dimmer intended for use in the USA for use with the UK electrical system.
    I have no idea if it's possible to do that safely, or if it will even work.
