Where to connect earth ground when there is no earth ground?
Discussion in 'General Electronics Chat' started by tpny, Mar 27, 2013.
  1. tpny
    May 6, 2012
    216
    Hi, I have a mobile (battery operated) device hooked up to a sensor. The sensor has 2 ground wires (circuit ground and earth ground). For circuit ground I connect to battery's (-) terminal. Where should I connect the earth ground to? (I'm ready to connect that ALSO to the battery's (-) terminal. Should I? Why or why not?)
    Thank you so much!
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    For a battery operated device you don't need to attach earth ground to anything. Just leave it unattached.
