Where to buy solder paste
Discussion in 'General Electronics Chat' started by jerseyguy1996, Jan 16, 2012.
  1. jerseyguy1996
    Thread Starter Active Member
    Feb 2, 2008
    206
    9
    I am going to be trying my hand at an all SMT layout for the first time and I am trying to find solder paste. It seems like it is really expensive to buy it online and I am not even sure which one to buy. Where do people typically buy the stuff and what parameters should I be looking for? Also does anyone in the New York/New Jersey area know of a place where you can just walk in and buy this type of stuff?
  2. Sparky49
    Jul 16, 2011
    835
    417
  3. jerseyguy1996
    Feb 2, 2008
    206
    9
    Yes thank you for that:rolleyes:
    The problem isn't finding solder paste online......I use google about 100 times a day......the problem is in understanding the differences between the $17 solder paste and the $2.50 solder paste which is what my question was but thank you anyway for the response.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Remember that solder paste is like "fresh food" and do have a shelf life. Typically around 4-6 month shelf life at room temperature. Water Soluble pastes get a little less shelf life. What you probably will run into is that paste thickening up over time which is attributed to the flux medium reacting with the solder powder. You might also see some separation of the flux. Symptoms of expired paste or paste that has changed significantly from its original properties include: Significant Separation of flux and powder, Increased viscosity (leads to difficult dispensing), and in some cases large air bubble formation in the syringe.
    The expiration date should be on the label. Many vendors will request the syringed solder paste be refrigerated to extend the shelf life. And that is trick you also should use. If you do not find any date on the label. Do not purchase it. No matter that they say in the shop.
  5. spinnaker
    Oct 29, 2009
    5,102
    1,190
  6. jerseyguy1996
    Feb 2, 2008
    206
    9
    I'm glad to know that I am not the only person that wasn't able to find the answer with just a quick google search.
  7. Sparky49
    Jul 16, 2011
    835
    417
    I believe that it has something to do with the tin content. More expensive pastes have higher levels of tin, which makes the paste melt evenly at the same temperature.
    For the sake of $2.50 it might be worth giving the cheap stuff a try. If it doesn't work very well, then you've only lost a couple of bucks.
    jerseyguy1996 likes this.
  8. mcgyvr
    Oct 15, 2009
    4,791
    976
    Sparky49 likes this.
  9. spinnaker
    Oct 29, 2009
    5,102
    1,190
  10. Markd77
    Sep 7, 2009
    2,803
    594
  11. CraigHB
    Member
    Aug 12, 2011
    127
    15
    I've been looking at solder pastes as well, been doing all my soldering by hand with wire solder since forever. Been thinking about doing some reflow.
    Like wire solder, you also want to consider the content of the solder itself. I think I would avoid the lead-free stuff. It has a much higher melting temperature. Similar to wire solder, I'd go with the 63/37 or 63% tin, 37% lead. The 62/36/2 is also good, has 2% silver and actually has a slightly lower melting point than 63/37.
    Unlike wire solder, it seems there's little option on the flux base. It seems most of them are "no-clean" flux. Probably just have to take what you get on that.
    You can get 63/37 paste from China pretty cheap by going to eBay or DealExtreme, but I have no idea if it's any good, plus shipping takes a while. Otherwise, it's expensive from the usual vendors like Digikey, Mouser, Newark, etc. I did find this one and it's Kester, but who knows.
