Thanks but I would like a chip which takes in 24VDC and generates a sine wave with +-5V and 5kHz (output) on osilloscope, as simple as that. The design of the chip can be Wien Bridge method, phase oscillator, etc etc. OSC1758 is my choice but unfortunely it is obsolete. Can I have other models (any company...as long as I get a sine wave of the above requirements)? As cheap and reliable as possible.I think this has been gone over before. You can easily male the oscillator from just about any op amp. If you include the lamp (the non-linear element), you obtain a really good sine wave output.
Your requirement are in conflict, though. You with a 24 volt single supply. Many op amps can work with a single supply, but you will have to check data sheets for ones that can use that level. And you want a bipolar output of + & - 5 volts. The op amp will have to have a bipolar supply to make the negative output voltage.
I use a dual op amp with an adjustment pot on the oscillator side for setting the frequency, and a level pot feeding the other side to adjust the output level. The op amps operate on +/- 12 volts.
Hey KFC Have some questions, What is you max THD? What is you max Freq shift? and what is the use for this? Is there some reason that you cannot use a Circuit instead of a chip? Is there Some reason that you cannot use a 1 chip IC for your freq gen, and use a Class A amp to pump up the power??Hello guys,
Where to buy a sine wave oscillator chip? What would be the model?
Specs: +-5V (10V peak-to-peak), 5kHz, single power supply of 24VDC
Best if it is cheap and reliable.
Thanks !!
by Jake Hertz
by Jake Hertz
by Robert Keim
by Duane Benson
