Hi Everyone,
I am using the following relay
http://www.maplin.co.uk/Media/PDFs/N17AW & N18AW.pdf
I m giving the 5V dc supply to the relay pins 1 and 16.
i read that if it is DPDT (Double pole double throw) it can be used as forward, off and reverse direction..I have searched from the internet how to connect
http://www.eleinmec.com/article.asp?12
http://uk.answers.yahoo.com/question/index?qid=20071116073906AA00xAj
but i m not getting it properly...can u suggest some solution or Can anyone suggest where the battery connections (3V battery on which motor operates)will go so that the motor should operate on relay in reverse/forward direction.(Please help by mentioning the pin numbers)
Many thanks
anju
Many thanks
anju
