where place solar panel
Discussion in 'The Projects Forum' started by mrel, Jun 12, 2011.
  1. mrel
    Thread Starter Active Member
    Jan 20, 2009
    98
    Hello
    Which is better to place a solar panel faceing east as the sun rise OR place solar panel faceing west as sun sets in the evening.
    Thank for the help mrel
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Bernard
    Aug 7, 2008
    4,242
    417
    If S is not an option, I would go for E as the panels will be cooler in the morning & more efficient. My panels face 190 degrees from true N @ an angle of 20 deg-fixed. Latitude 33 deg N.
  4. wmodavis
    Oct 23, 2010
    737
    150
    South! But only if you want to capture the most sun exposure. If you want to keep it cool keep it in the refridg. Max sun exposure out weighs a bit lower performance due to higher temperature.
  5. wayneh
    Sep 9, 2010
    12,396
    3,246
    Just curious (I'm doing some modeling of panel placement) - How did you arrive at the 20° position, given your latitude? Wouldn't the ideal angle be 33°, ie. to catch direct sun at high noon?
    Oops, should have read the link provided above - a good reference on the topic.
