Where I can buy a analog oscilloscope online (Europe)
Discussion in 'General Electronics Chat' started by thumb2, Dec 3, 2015.
  1. thumb2
    Oct 4, 2015
    88
    Hi all,
    I am looking for an analog oscilloscope and I am doing it online. I know that today DSO are used (I have one) etc..
    I know there are sites where I can buy also used, but I would like to avoid buying from ebay..
    There is some dedicated online web site where I can look for ?
    Any suggestion ?
    Thank you in advance.
    Regards.
    thumb2
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,367
    642
    Google for "surplus test equipment"
    I can understand your reservations about buying a scope on eBay, but it can be done successfully. That's how I got my first scope. It was a Tektronix 7704a that was shipped 2000 miles and arrived in working condition.
    I've bought scopes on eBay from local Sellers that had a pick up option.
    I've also had some luck with people selling locally (do you have Craigslist?). I traded a Tek scope to someone in my area.
    thumb2 likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    Where are you located?
    That way we can possibly give localized info.
    Bertus
    thumb2 likes this.
  4. KeepItSimpleStupid
    Mar 4, 2014
    1,250
    218
    Analog scopes are not made anymore. They have to be "used".
  5. nsaspook
    Aug 27, 2009
    3,006
    2,348
  6. Dodgydave
    Jun 22, 2012
    5,130
    766
  7. dl324
    Mar 30, 2015
    3,367
    642
    Electronics is my hobby and I prefer to use analog scopes. DSO's are blind most of the time and if you don't have a pretty good idea of what you're looking at, or for, you can miss things.
    I have an old 2GS/S HP scope that I get out every once in awhile to play with, but quickly put it away because it's just not very useful; only 2 channels, big, clunky, and noisy. I bought it for the logic analyzer and pods, but I do most of my debugging with a smaller 16 channel Tek plug-in. I have a 70 MHz DSO plug-in for my Tek scopes that I use occasionally; but for fun, not out of necessity...
    thumb2 likes this.
  8. thumb2
    Oct 4, 2015
    88
    Hi thank you for your infos. I am located in Spain.
    I know that it would be used. The most important is that it should work right.
    I would like to buy from a trusted seller (of course).
    Thank you all!
  9. GopherT
    Nov 23, 2012
    6,297
    4,019
    And that is exactly why the OP acknowledged that all DSOs would be used if bought today.
  10. ian field
    Oct 27, 2012
    4,447
    791
    Stewarts of Reading usually aren't cheap. But I'd expect them to back up their prices if after sales service proved necessary.
    Digital is all the craze and people are upgrading like crazy - sometimes you can pick up a CRO completely free or at least no more than scrap value.
  11. Dodgydave
    Jun 22, 2012
    5,130
    766
    I converted an old b/w tv set to a scope, ahh those were the days....
  12. ian field
    Oct 27, 2012
    4,447
    791
    IIRC: one of the very early issues of Elektor had a project for a TV scope adapter.
    Somewhere I've seen a project for a band IV/V spectrum analyser.
    The vertical sawtooth was scaled to 0 -33V to drive the varicaps in the tuner and the AGC was sampled by a comparator that drives the video amplifier.
  13. atferrari
    Jan 6, 2004
    2,663
    783
    Blind to what, precisely?
  14. nigelwright7557
    May 10, 2008
    488
    71
    I have bought 2 scopes off ebay.
    The first was bought as faulty with one channel working for £60.
    Did most of what I needed at the time.
    I eventually bought another fully working scope for £80 that was 100MHz and 2 working channels.
    It has worked for a couple of years with no issues.
    Buying second hand off ebay is OK if the scope works well.
    If it doesn't there is no chance of returning it unless the seller is a business.
  15. dl324
    Mar 30, 2015
    3,367
    642
    Waveforms. A DSO spends most of it's time storing, processing, and displaying data. If a signal has noise, it can miss the main event. In a digital circuit, it can miss a glitch.
    The same things can happen with analog scopes but to a lesser degree.
    thumb2 likes this.
  16. dl324
    Mar 30, 2015
    3,367
    642
    At least the OP already has a DSO; that makes it easier to repair/calibrate another...
  17. nsaspook
    Aug 27, 2009
    3,006
    2,348
    The high end DSO models trigger modes can see just about anything in near real-time.
    http://www.tek.com/document/application-note/real-time-versus-equivalent-time-sampling
    DSO scopes use interpolation of the waveform that can effect the displayed signal near the edge of it's resolution. The result may not be a true representation of the original on lower cost models due to differences in input bandwidth, sampling rate, ADC resolution (typically 8 bits on low cost units), and processor speed. You see the same effect with a high frequency analog scope but usually the effect is more gradual due to the greater dynamic range and smoother high frequency roll-off.
    http://cdn.teledynelecroy.com/files/whitepapers/wp_interpolation_102203.pdf
    thumb2 likes this.
  18. dl324
    Mar 30, 2015
    3,367
    642
    Here's an application note from Rhode&Schwarz, a DSO manufacturer, that discusses blind time and how they address it.
    Here's an interesting chart from that application note:
    thumb2 and nsaspook like this.
  19. ISB123
    May 21, 2014
    1,240
    531
