Where does the name Diode-Connected BJT come from?
Finaleblue
Joined Sep 22, 2014
7
In npn BJT, when the collector is shorted with the base we call it a diode-connected bjt.
How I understand it is, when we put a voltage source in shorted collector-emitter node and ground the emitter, the bjt acts like a small resistor.
What happens when we connect the voltage source on the emitter end and ground the collector in diode-connected bjt?
Assuming from the name "diode" I assume there should be no current until the voltage reaches some breakdown point.
So, long story short, can someone explain me why we call such bjt diode-connected?
WBahn
Joined Mar 31, 2012
30,045
On what basis to you claim that it acts like a resistor?
If it acts like a resistor, then if you double the current through it, you double the voltage across it. How does this reconcile with your understanding of the voltage across the base-emitter junction?
34,409
Shouldn't it be just linear since it acts like a resistor?
Why would you think something called a diode-connected BJT act like a resistor? :confused:
It actually acts like a diode which conducts current in the forward direction (the direction of the base-emitter arrow) with the logarithmic current versus voltage relationship of a diode, and blocks in the reverse direction until the reverse breakdown voltage of the base-emitter junction is exceeded.
The advantage of this connection is that it acts very close to an ideal diode at low currents, more so than a typical standard diode.
KL7AJ
Joined Nov 4, 2008
2,229
This configuration actual provided a constant current source; it's prevalent inside most op-amps. It's called diode connected because there are only two terminals from the "outside" universe.
Eric
WBahn
Joined Mar 31, 2012
30,045
Eric
As I read it, the configuration he is talking about is a voltage source connected directly across a diode-connected BJT. How does that provide a constant current source?
