where did I go wrong (phasor calculations)?
Discussion in 'Homework Help' started by Berticus, Apr 11, 2009.
  1. Berticus
    Dec 12, 2008
    Attached is the schematic.
    Z_C = -j2000 \\<br />
Z_L = j1000
    56.56 = (1500 + j1000)i_1 - j1000i_2 \\<br />
0 = -j1000i_1 + (1000 - j1000)i_2
    1000\angle90^{\circ}i_1 = 1414.21\angle-45^{\circ}i_2 \\<br />
1_1 = 1.41421\angle-135^{\circ}i_2
    56.56 = 1802.78\angle33.69^{\circ}(1.41421\angle-135^{\circ})i_2 - j1000i_2 \\<br />
= 2549.51\angle-101.31^{\circ}i_2 - j1000i_2 \\<br />
= (-500 - j2500)i_2 - j1000i_2 \\<br />
= (-500 - j3500)i_2 \\<br />
= 3535.53\angle261.87^{\circ}i_2 \\<br />
i_2 = 0.01600\angle98.1301^{\circ} = -0.0022624 + j0.01357
    i_1 = 1.41421\angle-135^{\circ}(0.01600\angle98.1301^{\circ}) \\<br />
= 0.022624\angle-36.8699^{\circ} = 0.018099 - j0.01357
    I_s = i_1 = 0.022624\angle-36.8699^{\circ} \\<br />
I_C = i_2 = 0.01600\angle98.1301^{\circ} \\<br />
I_L = i_1 - i_2 = 0.018099 - j0.01357 + 0.0022624 - j0.015837 \\<br />
= 0.0203614 - j0.029407 \\<br />
= 0.03577\angle55.301^{\circ}
    I_C is the only one that is correct. The other two are out of phase by 180^\circ. However, their magnitudes are correct.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    11-12th line down you have
    56.56 = (3535.53 @ 261.87°) i2
    hence
    i2= 0.016 @ 98.13°
    why not .....
    i2 = 0.016 @ -261.87°
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    No problem - your values are OK for i2 since +98.13° is the same as -261.87°.
    I think the problem occurs when you convert the polar form of i2 to rectangular form.
    I have ....
    i2 = .016 @ angle(98.13°) = -.00226 +j 0.01584
    whereas you have ....
    i2 = -.00226 +j 0.01357
