where can i get 'magnet wire'?
Discussion in 'Electronics Resources' started by CaliusOptimus, May 15, 2007.
  1. CaliusOptimus
    Aug 14, 2005
    59
    other than radioshack:p
    ive searched digikey, jameco, elec. goldmine and a few others, i cant find it anywhere. does it go by a different name or something?
  2. chesart1
    Jan 23, 2006
    269
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Radioshack has magnet wire for sale on their website. You did not mention what gauge magnet wire you are looking for so I am not sure it radioshack will have the gauge you are seeking.
    Actually, magnet wire is just solid conductor wire with a thin insulating coating on it. The coating is often enamel or lacquer.
    hgmjr
  4. CaliusOptimus
    Aug 14, 2005
    59
    yeah, ive got the wire from radioshack, i think it's 22, 26 and 30 guage. im looking for a larger guage (14-18) to make an electro magnet with just for fun :) ebay seems to have a good selection. but man, i wish copper grew on trees (silver too, for that matter) it's so durn expensive.
    btw, how do you stip the stuff? ive just been melting it off with my soldering iron.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Another method for removing the coating that I have seen used with success is to use a small square of wet & dry fine grit sandpaper.
    hgmjr
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I second the recommendation for fine grit abrasive paper.
    I get my magnet wire from Norvac.
  7. Solcar
    Member
    Jun 8, 2007
    21
    You might also consider an open coil crossover inductor for audio.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Fine grit? That's what they make Xacto knives for! Scrape it off. Burning it off with a flame works for larger guages, but does funny things to the annealing of the copper.
