Where can I get Linux from?
Discussion in 'Computing and Networks' started by chrischristian, Apr 2, 2008.
  1. chrischristian
    Thread Starter Active Member
    Feb 22, 2008
    43
    Does any one know that from where one can download setup ( .exe) kind of easy installation file for linux?, preferably of Fedora Core, and I want a full OS.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Linux doesn't come as an executable - it is a stand alone OS installation. You will need to download the ISO from the Fedora site beenthere linked to and then burn a disk image of the OS - this will be your installer disk or LiveCD.
    Dave
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have used several Live! CDs, Knoppex is quite good. It will allow you to get your feet throughly wet before jumping in. Broadband is required, but it is downloadable here...
    http://www.frozentech.com/content/livecd.php
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  6. cumesoftware
    Apr 27, 2007
    1,330
    11
    I would advocate the Ubuntu distro. It is an excellent distro. The best so far in my opinion.
    You can order two CDs for free. I ordered one for 32bit platforms and other from 64bit platforms. It allows you to try Linux before installing, and you can even check if the CD is damaged. It even runs on Windows (but only to demonstrate a few applications).
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Have you considered looking at Linux Mint? It is Ubuntu, so it has all the usability of Ubuntu, but with a much more polished UI and developed to be more media friendly with bundling a wide range of codecs for practically all media needs.
    A friend of mine suggested it so I gave the LiveCD a go a couple of weeks back - I was blown away by how good it was. Highly recommended.
    Dave
