Where can I get a high voltage (20kV-50kV) relay at a good price?
Discussion in 'General Electronics Chat' started by electronice123, Jun 1, 2009.
  1. electronice123
    Thread Starter Senior Member
    Oct 10, 2008
    304
    I need a high voltage DPDT relay, rated between 20kV-50kV, with a 12V coil and a switching speed of at least 1MHz.
    Does anyone know a good place to find one at a good price?
    Any help would be greatly appreciated!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can find vacuum relays that may handle the voltage, but they are electromechanical devices. The maximum on/off rate is likely to be 2 Hz.
    What is the application, and how much current gets switched?
  3. electronice123
    Oct 10, 2008
    304
    The application is just for a research project. A high speed switching transformer, done in a different way to see the effects.
    The current will be 100mA at most.
