I'm looking for information pertaining to washing of electronics boards, circuits, parts, in an industrial washer that is water based.
Yes Water!
I know it exists somewhere because i've heard of methods used or a method used to clean out a oscilloscope that needed precise measurements and it was suggest that every so --? years that the thing should be broken down and cleaned in a mild dish soap solution and sprayed out. Then thorough drying, of course.
I don't have a source for where i read this though. I don't think the service procedure suggested soaking the boards or boards though.
Or if anyone can tell me of there personally knowledge or how stuff is cleaned using water I'd really like to hear more on this. Any info would be great as it seems kind of crazy to wash something electronic in water unless it is well thought out on how it should be done. Please this topic has been in the back of my mind for years and i figured i'd see if this is common or Whatever.
I vaguely remember this but i don't know where.
Can anybody tell me of some models of water based "dish washing machines" for electronics or service manuals pertaining to certain prpcedures for cleaning elctronics???
I don't even know where to start for this type of topic.
I know from my own experience that when i used to go to the local landfill "Dump" i would find Potentially good Motherboards. The only problem is alot of times they would be wet covered with dirt and mud, grease, rain, and who knows what else. SO i would bring them home and clean them out using a bucket of hot sudsy water and finally give them a good spray with the hose for a rinse. I wouldn't soak them though. I never had a bad board from being wet. I have a Hot Tray also that i used to dry them out. The tray gets up to alittle below boiling, (probably 180 degrees is my round about guess) and i would cover the Motherboards with a cloth or cardboard to radiate some heat through them. I know that some of the SMD chips might be likely to hold some moisture or water underneath if not sufficiently dried. I've used this method at least 75 times for various parts over the years and the only side affect i noticed is if i use too much soap and too hot of water the metal traces would look likr it had been oxidised slightly. Some of the uncovered traces would have a slight amount of white on them.
I figured out how not to oxidize the circuits though...
Any info is better than no info. Please i'd like to know that it exists and learn something about this topic. -
[EDIT]::
Or Models, Makes of Industrial Washers, Manufacturers of Industrial Washers...Anything would be Excellent!!!
Thanks...
CHRIS
Yes Water!
[EDIT]::
Thanks...
CHRIS
