where can I find a 5 Volt solenoid
Discussion in 'The Projects Forum' started by And123, Mar 8, 2009.
  1. And123
    Mar 8, 2009
    I'm currently building a project for an electronics class, I need a 5 Volt solenoid that is to run off of a TTL PLC board.
    Where can I find a 5volt linear solenoid for a reasonable cost and where can I find one with as long as a shaft as possible?
    Thanks...
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Solenoids are getting to be hard to find, particularly for low voltages.
    What is it that you are attempting to accomplish?
    How long of a stroke do you need?
    Pushing or pulling?
    "Ding-dong" doorbells from the 50's through the late 70's had a pair of 24VAC solenoids in them; a single "ding" for the rear door, and dual-tone for the front. They had a fairly long throw. You could use a relay to switch power to the solenoid. A 24vac solenoid will operate on 17v-18v DC.
  3. Bernard
    Aug 7, 2008
    4,232
    414
    How long of a stroke? What is duty cycle, on-off? How much current is available? Can you re -wind one with help?
  4. JFEG
    Apr 5, 2009
    6 volt solenoid available at www.rapidonline.com jfeg
  5. JFEG
    Apr 5, 2009
  6. And123
    Mar 8, 2009
    Appreciate it guys, I ended up with a 24 VDC solenoid. This is to actuate a starting gate for a pinewood derby racetrack.
