Where can I buy a PQ3220-1000C transformer?
Discussion in 'Electronics Resources' started by z1k, Mar 23, 2009.
  1. z1k
    Mar 23, 2009
    5
    I've looked all over the net. I need this for my akai tv power supplier.
    thanks in advance
  2. z1k
    Mar 23, 2009
    5
    bumpidibump! ;)
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. z1k
    Mar 23, 2009
    5
    Yeah I saw that but that is the complete power supply, I'm only needing the transformer in it.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I think the transformers are custom made for AKAI.
    Perhaps AKAI can help you.
    Greetings,
    Bertus
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    It might be cheaper and quicker to replace the whole supply... such is the curse of our modern "throw away" economy.
  7. gregdevid
    Member
    Feb 4, 2009
    18
    Hi Friend,
    I have an Akia 200watt SMPS.The supply powers a 27 inch lcd display. Originally it had 5v standby power only and would not turn on. Almost all of the output capacitors were domed and leaking. I replaced all of the output caps with low esr, high frequency caps of the same voltage and capacitance. Both main filter caps were replaced also.
  8. z1k
    Mar 23, 2009
    5
    Thanks,
    I'm pretty new to electronics. How do I find out the specs of a capacitors or the transformers so I can get an equial part to replace them?
    Once again thanks.
