Where can I buy a mini USB port online?
Discussion in 'General Electronics Chat' started by andynov123, Dec 12, 2011.
  1. andynov123
    Dec 12, 2011
    6
    I'm having problems finding where I can buy a mini USB port online? Can anyone help me?
  2. DumboFixer
    Feb 10, 2009
    219
    34
    Knowing which country you are in would help people here recommend a supplier.
  3. andynov123
    Dec 12, 2011
    6
    USA Florida
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    Do you mean a hub?
    And mini 5 pin or 4 pin or do you need micro
  5. andynov123
    Dec 12, 2011
    6
    The mini USB port on my external HDD lost one of its pins there were 5 pins before one broke off and I do not believe it is micro
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    They are not all identical.
    Do you have the drive opened up so that you can see the connector?
    Are there any letters or numbers on the body of the connector?
    Can you take a photo of it?
    [eta]
    Go on www.digikey.com
    Search for: mini USB connector
    On the results page, under "Connectors, Interconnects", click on "USB, IEEE-1394 (Firewire), DVI, HDMI (155 items)"
    Under "Number of Contacts", click "5", then the "Apply filters" button.
    That narrows it down to 6 pages worth.
    There are three types of the mini USB connectors; A, B, and AB. They are shaped slightly differently. Note that in the following image examples, only the shape of the opening is important:
    [eta]
    Selecting "USB - Mini B" narrows it down to 5 pages.
    Then it's down to matching the existing mounting. You will have to open up the drive in order to find out what you need.
  7. mcgyvr
    Oct 15, 2009
    4,791
    976
  8. andynov123
    Dec 12, 2011
    6
    Its the mini Usb-b I think. Heres a pic so you tell me?
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yours is a Mini-USB type B.
    [eta]
    I had edited my prior reply to include the information on Digikey and the images of the port types; I didn't realize there were more replies at that point.
  10. andynov123
    Dec 12, 2011
    6
    Where can I buy a Mini-USB type B in the USA online?
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See my reply #6, above.
    There will still be many to choose from after you get to Mini USB type B.
  12. mcgyvr
    Oct 15, 2009
    4,791
    976
    I'd pop open the case and take a good look at it then head over to digikey or newark or mouser and just start looking through the datasheets till you find the exact one.. All the manufacturers might have slight differences in where the shield pins are ,etc..
  13. andynov123
    Dec 12, 2011
    6
    I called the hdd manufacturer Western Digital and they told me it was mini usb type b now where can I purchase one online in USA?
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
