Where can I buy a 12v dc 5Amp power supply locally (in phx)
Discussion in 'General Electronics Chat' started by mackeymartin, Apr 28, 2012.
  1. mackeymartin
    Dec 31, 2011
    7
    Anyone know where can I buy a 12v dc 5Amp power supply locally (in phx)?
  2. KJ6EAD
    Apr 30, 2011
    1,426
    363
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    You can get one on ebay for about $8 including shipping.
  4. panic mode
    Oct 10, 2011
    1,328
    305
    you don't have any old PC collecting dust?
  5. mackeymartin
    Dec 31, 2011
    7
    Yes I do have an old PC lying around.
    What are you saying? I can use the old PC power brick?
    Do I just use one of the red/which plugs that is normally used to power a dvd rom drive?
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Is it an ATX or ATX plus 12 form factor power supply?
    http://en.wikipedia.org/wiki/ATX
    (See the pinout about 1/4 the way thru the article)
    If so, google "ATX Bench Supply" for lots of ideas on converting one of these supplies to a useful bench power supply. You will need to place a load of a couple of Amperes on the 5v supply to get a reasonably well regulated +12v out.
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Actually you need a terminal like seen in the attachment.
    You need to ground the green wire for startup.
    It's possible to use only 12V, however, if you load it with some Amps (about 5 Amps), it will move towards 10 volts.
    The HF transformer indeed needs a reasonable balance (means load on 5 volts as well). Most modern ATX supplies (this one maybe 5 to 6 years old) don't need any kind of dummy load. These were needed for some older supplies (like 386, PC AT, PS/2 etc.)
    PS. if you use a terminal like in the picture, you need to tin the wire, or it will come loose very easily.
  8. Tobias
    May 19, 2008
    158
  9. bountyhunter
    Sep 7, 2009
    2,498
    507
