Where can I browse through Open Source PCBs & download the Gerber files?
Discussion in 'General Electronics Chat' started by acthomas, Oct 5, 2016.
  1. acthomas
    May 9, 2016
    What is the best place for me to download Open Source PCB Gerber files that I could then modify and have manufactured?
  2. kubeek
    Sep 20, 2005
    4,687
    805
    How are you going to modify gerbers? That is a very tedious job and you basically can´t do any major changes. You need to download the original design files and have the proper program. And no, I never heard of any place with multiple projects to be downloaded, only some small projects that provide the design files. Is there some specific device you want, or why do you want just the gerber files of any pcb?
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    No place that I know of.
  4. GopherT
    Nov 23, 2012
    6,303
    4,019
    Are you assuming standard PCBs exist for various projects or consumer products?
    http://dirtypcbs.com/view.php has some customer's diy projects posted and you can order the boards that they had previously produced but there is
    - no way to modify a Gerber,
    - no way to know exactly how the board is intended to work
    - no way to know all the component values (unless lucky enough to find a designer who put labels on the board
    - no way to figure out / re-design the firmware for any microcontrollers used in the project.
    - no way to know any connections to off-board parts and response from the off-board parts
    And so much more...
  5. hp1729
    Nov 23, 2015
    2,087
    232
    well now, there's an interesting concept. Given the general design of some circuits, we share schematics, why not circuit board designs?
    Basic power supply designs. Bridge rectifier to LM317 with the option of a booster transistor.
    LM555 astable multivibrator with a kluge area.
    Differential amplifier
    Active filter
    Plus and minus supply using LM78xx and LM79xx regulators.
    Kluge boards
    Breadboard support circuits
  6. hp1729
    Nov 23, 2015
    2,087
    232
    What type of circuit were you looking for?
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    Just modify the schematic and board design, then make your own Gerber's. My design program (Eagle) makes Gerber's in a few seconds, if that from the .brd file.
    John
  8. hp1729
    Nov 23, 2015
    2,087
    232
    Can you convert from PCB design to schematic with Eagle?
    acthomas likes this.
  9. jpanhalt
    Jan 18, 2008
    5,699
    909
    No. But you can modify a .brd file in Eagle without the schematic.
    John
  10. hp1729
    Nov 23, 2015
    2,087
    232
    Cool!
  11. nerdegutta
    Dec 15, 2009
    2,565
    805
  12. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Most of the PCB manuf. either sell open source boards or their own various misc designs, one of these may fit the bill?
    Oshpark, Itead, DirtyPCB etc.
    Max.
