where am I going wrong
Discussion in 'Math' started by kolahalb, Sep 28, 2007.
  1. kolahalb
    Sep 25, 2007
    6
    I stumbled at the answer of a problem solved in Reily-Hobson-Bence.Please check if I am wrong:
    Find the parts of the z-plane for which the following series is convergent:
    ∑[(1/n!)(z^n)] where n runs from 0 to ∞
    Cauchy's radius: (1/R)=Lt (n->∞) [(1/n!)^(1/n)]
    Changing variables as 1/n=t,the limit becomes (1/R)=Lt(t->0) [(t!)^t]
    I am having the limit as 1 and hence,R=1...but the book says Since
    [(n!)^(1/n)] behaves like n as n → ∞ we find lim[(1/n!)^(1/n)] = 0. Hence R = ∞ and the series is convergent for all z
  2. kolahalb
    Sep 25, 2007
    6
    I resolved the problem in this manner: (1/n!) falls at a much faster rate than that of (1/n).As a result the function is decreasing all the way starting from the highest value one and always being positive.If you draw a graph,the curve should tend to zero as n tends to infinity...
  3. DMaiorca
    Oct 15, 2007
    I think I spotted your error:
    In actuality, the sub should have been (1/R)=Lt(1/t->0) [(t!)^t]
    Its the simple stuff that always messes with me, too!
  4. mogadeet
    Member
    May 1, 2007
    19
    hey kolahalb
    your series does indeed converge everywhere in the complex numbers. it is just exp(z). obviously (1/n!) tends to zero and so a-fortiori its n-th root tends to zero. hence 1/R = 0 and R is infinite.
    note incidentally that (1/n!) is 1/(n!) and not (1/n)! the latter is undefined for n<>1 [what is (1/2)! for example?]
    peace
    stm
