When using veroboard/stripboard, is it best to cut the tracks first or solder first?
donzle92
Joined Jun 12, 2011
Im going to have to cut the track in the adjacent hole right next to where i solder various components. So is it best to cut the track first then solder or will that make it difficult to produce a good joint? If I try to cut the track after solder it may damage the joint.
As I say I have to cut the track in the hole next to where the component will be soldered in many cases, otherwise it wouldnt be a problem either way.
Im fairly new to soldering so whats the best method?
