When to use this device?
Discussion in 'General Electronics Chat' started by Tobias, Jan 11, 2010.
  1. Tobias
    Thread Starter Active Member
    May 19, 2008
    158
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It lets a microprocessor know if some critical voltage level is present. Like for some external device. Google the part number. They come preset for anything from 800 mv to 6 volts.
  3. Tobias
    May 19, 2008
    158
    I noticed looking through the spec sheet there is alot of variations to it. Thanks
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I have seen these devices or similar used in beambots.
    hgmjr
  5. BMorse
    Sep 26, 2009
    2,675
    234
    These devices are normally used to reset a microcontroller if the voltage falls below a certain point, mostly these are used as "brown out" detectors, they usually hold the output at that level until the voltage goes back up to a suitable range for the uc to function...
    The ones used in Beam bots are actually voltage triggers, they operate in the exact opposite as the supervisory IC, the ones used in Beambots are ones that trigger when a voltage reaches a certain point (solarbots use these types to monitor capacitor charge level, when it reaches a certain voltage, it will either set an output low or high depending on device to trigger a motor or coil.)
    My .02
