When building your own may be better than improvising
Discussion in 'The Projects Forum' started by burger2227, Feb 15, 2014.
  1. burger2227
    Feb 3, 2014
    192
    24
    I just built an "Instructable" where you tear apart a recyclable camera to get 100 volts to power a CFL light bulb with one AA battery. I happened to have all of the parts, including 2 cameras I never used in my car trunk.
    I managed to pry the bottom off of the CFL bulb and figured I could probably fit whatever I needed into the base to replace the CFL driver. Well one camera had a neon bulb indicator and the other LED. The neon bulb never lit, but the circuit still charged up with me completely unaware of it. Testing the capacitor proved me right! I really liked that old screwdriver...
    It gets worse because the secondary transformer raises voltage to 1000 volts which hopefully will never happen once you tear the camera apart.The flash plate is often out in the open too!
    Anyhow I was wondering if anybody here has made an oscillator and transformer deliver 100 volts as that has to be a safer way than tearing apart a disaster waiting to happen. Especially for newbies who like the idea and are clueless. The Instructable author even kept the other transformer in the circuit he made.
    I don't mind making my own transformer if there are none readily available. I'd like to make one with a rechargeable button battery inside to really mess with my friends. :)
    Thanks all!
    Here's my building process if interested: http://petesqbsite.com/phpBB3/viewtopic.php?f=4&t=3817
  2. shteii01
    Feb 19, 2010
    3,514
    514
    Um... Isn't it natural selection at work? Do we really want simpletons in the gene pool?
  3. burger2227
    Feb 3, 2014
    192
    24
    Well look at all of the geniuses in the Olympics trying to kill themselves to be famous! Ya gotta start somewhere to get your 15 minutes of fame... :D
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    I think threads about doing stupid things that can kill you are not within the forum guidelines......:eek:
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    But they have millions of people watching.
    Where is the fun of sitting alone at home in your lab electrocuting yourself if nobody gets to enjoy watching....
    rc3po and absf like this.
  6. bertz
    Member
    Nov 11, 2013
    239
    32
    Here is the oscillator circuit for the CD ignitions we experimented with for our RC airplane engines. We ultimately gave up trying to make our own because the prices from China got to the point these were a throwaway if damaged.
    Since you don't mind winding your own transformers, here is a link for making the transformer in this circuit. Give you something to do on those long winter nights.
    http://ot40.com/making_the_transformer.htm
    Good luck
    Al
  7. burger2227
    Feb 3, 2014
    192
    24
    I have cameras on me at all times. If they make Utube so much the better. Maybe I can get a Darwin award...
    How is that any better than sitting there quoting me? :)
    Honestly, the real techs must be watching those Olympics. Shocking!
    Bertz I wanted to make low current high voltage AC, not use it to make low voltage supplies from AC.
  8. burger2227
    Feb 3, 2014
    192
    24
    I found this circuit which even tells you the transformer configuration:
    I'm only interested in the part on the left side, but almost 2000 thousand wraps is a lot of winding. Maybe I could use my drill...
  9. djsfantasi
    Apr 11, 2010
    2,911
    881
    Ok, my strange sense of humor is kicking in once again. Is there any one else who finds the name of the schematic ironic?
  10. rc3po
    Member
    Feb 12, 2014
    56
    Lmao!! I guess we need to always have a camera going so if we kill ourselves, at least people can watch the video...
    That was funny - you made my day!
  11. Brownout
    Jan 10, 2012
    2,375
    998
    Why not just use the transformer from the flash unit?
  12. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    You can produce 300V with a NE555 and one coil (but needs a good transistor + more than 1.5v)
    No need for 2000 windings.
    How about a few RF inductors + put a few turns on each (but it will be a little lossy). Worth trying. Generate the pulsed signal otherwise + get rid of the third winding.
  13. atferrari
    Jan 6, 2004
    2,670
    785
    Fame? Amongst your relatives only if you work in your bench, most probably alone! :p
  14. burger2227
    Feb 3, 2014
    192
    24
    I found this circuit with a readily available transformer. It runs on 5 volts with just one transistor. I wouldn't need anything else but a 1K resistor. That would drive the CFL.
    http://www.diyphotography.net/how-to-build-a-flash-with-an-optical-slave
    It is only 16 X 13 mm in size. Oddly enough, the CFL circuit board has a transformer on it the same size. I might be able to figure a way to put the circuit on that circular board. I found one that works on one battery too:
    http://xenonflashtubes.com/components.html
