When ac & dc sources in a single circiit
Discussion in 'Homework Help' started by CrktMan, May 25, 2006.
  1. CrktMan
    Thread Starter Active Member
    Nov 29, 2005
    34
    Problem in general:
    A circuit has 2 current sources, one ac and another one dc, and a third ac voltage source. Circuit parameters are an inductor, a capacitor and a resistor. We have to find current through the inductor.
    My idea of solution:
    Apply superposition theorem: When only dc current source is considered, make the capaitor open for dc and inductore short for the current source. And take into consideration the current amount through the shorted inductor.
    Two other ac sources can be taken into account one at a time while ignoring the dc current source.
    Final current can be obtained by adding three currents all together.
    Please rectify me as necessary. Thanks.
    CrktMan
  2. haditya
    Jan 19, 2004
    220
    seems fine under steady state conditions
  3. JoeJester
    Apr 26, 2005
    3,401
    1,218
    CKTman,
    Can I assume the components are connected in series?
    If so, then once the capacitor has an equal DC charge on both plates, the current is essentially zero.
    And if they are in series, there will come a point where the inductor current is maximum [at the resonant frequency] in that resonant circuit [again, assuming a series connection with the three components].
