Wheatstone bridge
Discussion in 'The Projects Forum' started by dsp_redux, Mar 5, 2010.
  1. dsp_redux
    Thread Starter Active Member
    Apr 11, 2009
    182
    5
    Hi, I'd like to build a Wheatstone bridge to measure a resistance with precision. The thing is, all the examples I have seen are for Wheatstone bridges where you need to manually balance the bridge with a potentiometer. Since I'm "reading" the resistance (in fact a precision temperature probe) on a regular basis, I wanted to hook that bridge to an acquisition card (DAQ) to read the output voltage. Is it possible for the bridge to give me between 1V and 10V if the unknown resistor is from 24880 to 29860 ohms ?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    With only one variable resistance, life might be simpler using a fixed resistor in series and a very stable voltage supply. Take the changing voltage at the junction between the two resistors and apply an op amp to span the desired offset and response.
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    The idea of the bridge is to bring it into ballance. What you would end up with would not be a bridge really.
  4. DickCappels
    Aug 21, 2008
    2,758
    667
    Yes, it is possible to process the output of the bridge so that the output voltage will be between 1V and 10V when the resistance being measuerd varies from 24880 to 29860 Ohms.
    if you bridge is DC, and the output is already referenced to ground, so much the better.
    For the most part, its a matter of resistors and opamps.
  5. dsp_redux
    Apr 11, 2009
    182
    5
    DickCappels: Got it! I'll be using an AD623. Thx everyone.
