wheatstone bridge query
Discussion in 'General Electronics Chat' started by paulmc, Aug 1, 2006.
  1. paulmc
    Aug 1, 2006
    9
    does anyone know why we use wheatstone bridges for measurement circuits?
    cheers
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    http://en.wikipedia.org/wiki/Wheatstone_bridge
    measuring instrument invented by Samuel Hunter Christie in 1833 and improved and popularized by Sir Charles Wheatstone in 1843. It is used to measure an unknown electrical resistance by balancing two legs of a bridge circuit, one leg of which includes the unknown component. Its operation is similar to the original potentiometer except that in potentiometer circuits the meter used is a sensitive galvanometer.
    Wheatstone's bridge circuit diagram.
    Enlarge
    In the circuit to the left, Rx is the unknown resistance to be measured; R1, R2 and R3 are resistors of known resistance and the resistance of R2 is adjustable. If the ratio of the two resistances in the known leg (R1 / R2) is equal to the ratio of the two in the unknown leg (Rx / R3), then the voltage between the two midpoints will be zero and no current will flow between the midpoints. R2 is varied until this condition is reached. The current direction indicates if R2 is too high or too low.
    Detecting zero current can be done to extremely high accuracy (see Galvanometer). Therefore, if R1, R2 and R3 are known to high precision, then Rx can be measured to high precision. Very small changes in Rx disrupt the balance and are readily detected.
    If the bridge is balanced, which means that the current through the galvanometer Rg is equal to zero, the equivalent resistance of the circuit between the source voltage terminals is:
    R1 + R2 in parallel with R3 + R4
    R_E = {{(R_1 + R_2) \cdot (R_3 + R_x)}\over{R_1 + R_2 + R_3 + R_x}}
    Alternatively, if R1, R2, and R3 are known, but R2 is not adjustable, the voltage or current flow through the meter can be used to calculate the value of Rx, using Kirchhoff's circuit laws (also known as Kirchhoff's rules). This setup is frequently used in strain gauge and Resistance Temperature Detector measurements, as it is usually faster to read a voltage level off a meter than to adjust a resistance to zero the voltage.
    First, we can use the first Kirchhoff rule to find the currents in junctions B and C:
    I_3\ - I_x\ - I_g\ =\ 0
    I_1\ + I_g\ - I_2\ =\ 0
    Then, we use Kirchoff's second rule to find the voltage in the loops ABD and BCD:
    I_3 \cdot R_3 + I_g \cdot R_g - I_1 \cdot R_1 = 0
    I_x \cdot R_x - I_2 \cdot R_2 - I_g \cdot R_g = 0
    The bridge is balanced and Ig = 0, so we can rewrite the second set of equations:
    I_3 \cdot R_3 = I_1 \cdot R_1
    I_x \cdot R_x = I_2 \cdot R_2
    Then, we divide the equations and rearrange them, giving:
    R_x = {{R_2 \cdot I_2 \cdot I_3 \cdot R_3}\over{R_1 \cdot I_1 \cdot I_x}}
    From the first rule, we know that I3 = Ix and I1 = I2. The desired value of Rx is now known to be given as:
    R_x = {{R_3 \cdot R_2}\over{R_1}}
    If all four resistor values and the supply voltage (Vs) are known, the voltage across the bridge (V) can be found by working out the voltage from each potential divider and subtracting one from the other. The equation for this is:
    V = {{R_x}\over{R_3 + R_x}}V_s - {{R_2}\over{R_1 + R_2}}V_s
    This can be simplified to:
    V = \left({{R_x}\over{R_3 + R_x}} - {{R_2}\over{R_1 + R_2}}\right)V_s
    The Wheatstone bridge illustrates the concept of a difference measurement, which can be extremely accurate. Variations on the Wheatstone bridge can be used to measure capacitance, inductance, impedance and other quantities, such as the amount of combustible gases in a sample, with an explosimeter. The Kelvin bridge was one specially adapted for measuring very low resistances. This was invented in 1861 by William Thomson, Lord Kelvin.
    The concept was extended to alternating current measurements by James Clerk Maxwell in 1865, and further improved by Alan Blumlein in about 1926.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings paulmc,
    Here is a link to the AAC tutorial on Wheatstone Bridge.
    http://www.allaboutcircuits.com/vol_1/chpt_8/10.html/wheatstone
    Take a look at the material and see if it helps you gain some additional insight into the advantages that such a circuit provides.
    hgmjr
  4. paulmc
    Aug 1, 2006
    9
    thank you much appriciated
