Hello guys
I'm trying to convert the analogue signal from a load sensor to digital and send the digital signal to a rs232. I'm planing to use 10v for the excitation.
Rated Load capacity is 10t
Rated Output 2mV/V
From previous thread I got the idea of using and op-amp to enlarge the output signal and from there connect it the ADC.
How I determined what resolution of ADC I should use?
Any advice on what op-amp should I be using?
Are they any parameter I need to know?
Thank you in advance...
Rated Output 2mV/V
