wheatstone bridg...how found ig..??
astastg
Joined Nov 28, 2015
helllo all..
this my first time here..so welcom all
amm..yeah here we go!..
guys..how i can found ig from this form ..
and what does mean by prove my rsult in any simulation software,..?
any one can hellp me to draw it..?
can we put ig over there..?
Dodgydave
Joined Jun 22, 2012
11,303
Work out the voltage on each side of the bridge using ohms law, then subtract one side from the other to give the voltage across the meter, and that will give you its current and direction.
Ans 1.49mA right to left
astastg
Joined Nov 28, 2015
Work out the voltage on each side of the bridge using ohms law, then subtract one side from the othe to give the voltage across the meter, and that will give you its current and direction.
oh ..yeah i see i will do this steps thanx
but did you know which best program can use for draw that circuit..
Q...:
WBahn
Joined Mar 31, 2012
30,060
Except that since the bridge isn't balanced you can't use Ohm's Law to determine the voltage on each side of it.
There are several ways to tackle the problem, depending on how much analysis background you have at this point. In the order that you likely are exposed to them, you have brute force KVL/KCL, nodal analysis, mesh analysis, delta-wye transforms, and Thevenin equivalent circuits.
What methods do you know so far?
As for "prove your result in any simulation software", a better phrasing would be to verify your result, but what they are asking you do to is simulate the circuit, apparently using any simulation software of your choosing, and show that the simulator yields the same results that your calculations do. A lot of people here use LTSpice, which is free and fairly easy to use.
WBahn
Joined Mar 31, 2012
30,060
First, this is homework, so just offering up answers doesn't help the TS learn.
Second, ask if your answer makes sense. Look at the original circuit and determine whether ig, as the TS defined it, will be positive or negative?
Next, put some bounds on what the answer can be by determining the voltage across the galvanometer assuming that it has infinite resistance. The absolute most current that could possibly flow in the galvanometer would be this voltage divided by the actual galvanometer resistance.
astastg
Joined Nov 28, 2015
yeah on the way..^^
thanx Dr.WBahn
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Just guessed i am not sure
