what's wrong with my counter?
Discussion in 'The Projects Forum' started by yasir_66, Jul 11, 2009.
  1. yasir_66
    Thread Starter Active Member
    Jun 25, 2009
    71
    when i touch any soldering point the circuit becomes normal & when i dont touch the unwanted counting begins
  2. Mike2545
    Mar 26, 2009
    116
    What counting circuit are you using? It sounds like you need to add capacitance.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. yasir_66
    Jun 25, 2009
    71
    yes the same circuit
    & what was bertus suggestion?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Bertus suggested that you post a photograph of your circuit.
    You also need to post an updated schematic of your circuit, since you said in the thread that you had added other components.
    Without complete information, we can't give you a good answer.
    Also, this thread should be merged in with the original thread.
