Whats with the microphone?
Discussion in 'General Electronics Chat' started by corefinder, Jul 18, 2013.
  1. corefinder
    Oct 6, 2011
    55
    Hi
    I was thinking of making a clapping circuit. But I am confused how microphone works. The one which I have is small drum like. I tried to get some voltages through multimeter but it did not give any good voltages. I dont know if voltages coming in multimeter are from microphone. I want to know how to check microphone and what kind of microphone should I be looking for in market and what are the voltages you might get from that microphone?
  2. wayneh
    Sep 9, 2010
    12,374
    3,226
    You need to know more than that. There are several types and some need to be powered. The rest of the circuitry depends on which type you want to use.
  3. corefinder
    Oct 6, 2011
    55
    Can you provide any good stuff to read from about microphones. I want one for the clapping circuit. can you specify which type of microphone could be used with that.
  4. wayneh
    Sep 9, 2010
    12,374
    3,226
    Metalmann likes this.
  5. tubeguy
    Nov 3, 2012
    1,157
    197
    Can you post some clear photos of it, front, back?
    If it's a condensor mic, it will work fine, but it needs a proper voltage supply and preamp circuit.
  6. Metalmann
    Dec 8, 2012
    700
    223
    Thank you for posting that video. I'm not quite as confused now.;):D
