whats (UBRRH=BAUD_PRESCALE>>8)?
Discussion in 'Embedded Systems and Microcontrollers' started by khan yousufzai, Oct 16, 2012.
  1. khan yousufzai
    Aug 31, 2012
    19
    in the below program BAUD_PRESCALE =((crystal freq/(baudrate*16)-1)=77
    now i should do,UBRRL=BAUD_PRESCALE,BUT IN THE FOLLOWING FUNCTION ONE THING MAKES ME CONFUSED,UBRRH=(BAUD_PRESCALE>>8);WHATS THIS? PLEASE EXPLAIN,,,,THANKS SO MUCH,THE REAL HUMINITY
    void usart_init()
    UCSRB |= (1<<RXCIE) | (1 << RXEN) | (1 << TXEN); // Turn on the transmission and reception circuitry
    UCSRC |= (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1); // Use 8-bit character sizes
    UBRRL = BAUD_PRESCALE; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
    UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    >> is the shift right operator
    << is the shift left operator
    The left operand is shifted left(right) by a number of bits equal to the right hand operand. It is a common way to refer to the upper byte of a 16-bit word.
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    If you have a BYTE PTR (or a char pointer), instead of shifting 8 times,
    you could use *(byte_ptr+1)
    If the upper byte is zero in your program, you can simply blank the destination. The lines maybe come from a generic template, where in some cases, the upper byte might be non-zero.
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    As has been noted the >> is the C shift operator. { something >> 8 } is one way to rotate the high byte of a 16 bit quantity to the lower byte.
    If you would start with:
    BAUD_PRESCALE = 0b1010101001010101;
    then UBRRH would equal 0b10101010, or the high byte portion.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    And most compilers are smart enough to avoid shifting if at all possible. Some might argue that the shift operation has more clarity than the pointer operation.
