What's this growing on the solder joint?
Discussion in 'General Electronics Chat' started by Stringybark B, Mar 18, 2016.
  1. Stringybark B
    Jul 22, 2015
    5
    Hey all,
    I opened my 7 year old remote presenter pointer to figure out why it's suddenly stopped working.
    Could this stuff that's growing on the solder connecting the battery spring to the board be causing the current not to supply to the circuit?
    If so, can I fix this by reheating the solder, removing it and adding new? Or is it a waste of time?
  2. #12
    Nov 30, 2010
    16,705
    7,355
    Clean the wad off and see how much damage happened.
  3. Stringybark B
    Jul 22, 2015
    5
    Cleaned up version: cleaned.jpg
  4. Kermit2
    Feb 5, 2010
    3,852
    968
    It's the electrolyte which leaked from the battery.
    Very corrosive stuff. Soft toothbrush, isopropyl and plenty of gentle scrubbing will get it clean.
    Use an ohm meter and verify continuity across corroded traces. Use jumper wires and solder to reconnect components if a trace is open.
    Finally, some advice you probably know now. Don't leave the battery in it when stored away.
    Stringybark B likes this.
  5. #12
    Nov 30, 2010
    16,705
    7,355
    Is that copper trace open by the letter A or has it survived because it has both the green coating and a white line protecting that little bit of copper?
    You're going to have to get in there with a 10X jewelers loupe to see if the corrosion ate the end off that yellow capacitor.
    Maybe the light green line (on the other side of the solder blob) on the battery holder got dissolved.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    The capacitor appears to be a 47uf 10V.
  7. Stringybark B
    Jul 22, 2015
    5
    That copper trace sure looks open, not just in the photo but under the magnifying glass as well.
    The capacitor kind of looks OK after I cleaned up around it some more. But that copper trace is definitely open.
    The photo is reasonably clear, I think.
  8. Stringybark B
    Jul 22, 2015
    5
    Seems to be a 'lets bin it' situation, right?
  9. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    You can use wire to bridge the open.
  10. Dodgydave
    Jun 22, 2012
    5,159
    772
    You can rework the copper track with solder and wire strands.
  11. wayneh
    Sep 9, 2010
    12,396
    3,246
    I agree with the assessments of the problem, and that it can possibly be repaired with some effort. If you have the tools and skill to do it, it may be worth your effort. (Success may hinge on whether that capacitor is disconnected/destroyed or not.) If you have neither the tools nor the skills, it's unlikely to be worth it.
  12. Picbuster
    Member
    Dec 2, 2013
    391
    53
    Small advice: Always coat pcb's. Use conformal coat this will protect yr PCB and components.
    I use HPA )1ls. operational from -60 to 130 degree centigrade. See http://www.electrolube.com/
  13. Stringybark B
    Jul 22, 2015
    5
    I'll give it a try. Won't take too long and I might get it to work. If not, well, I will have learnt something.
