what's this component?
Discussion in 'General Electronics Chat' started by rajeshsura, Mar 12, 2014.
  1. rajeshsura
    Feb 25, 2014
    Could you pleas help me with identifying the component that is pointed to? It is located close to the EMI filter.
    Thanx in advance.
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    probably a capacitor but could be a fuse
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    Sorry can't tell. Bad picture.
    Need info on what the silk screen says beside tht component.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    If this component is named L3 it is most probably some inductor
  5. R!f@@
    Apr 2, 2009
    8,792
    771
    I believe L3 is the toroid one
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Yes that is correct, could very well be that L3 is the common mode choke like thingy.
  7. Externet
    Nov 29, 2005
    780
    58
    Looks like a longer ferrite bead to me. I have a few. Measure resistance, should show 0 ohm. And perhaps the grey body is not secured to its leads, unless it is a surface mount type.
