What's this Capacitor warning?
Discussion in 'General Electronics Chat' started by jut, Feb 26, 2008.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    I have couple capacitors I removed from an old computer (1980s) that reads...
    4700 uF 63V
    CAN NOT ISOLATED
    MADE IN UK
    8345
    Can someone tell me what "CAN NOT ISOLATED" means? It can't be used by itself?
  2. lightingman
    Apr 19, 2007
    374
    22
    Hi,It means that the metal can of the capacitor is not electricaly isolated from the internal structure.... Therefore if it is used with a capacitor clip, you should not damage the insulating material....Daniel.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It is likely that electrolytic capacitors that old are no longer good. The electrolyte in them dries out.
  4. jut
    Aug 25, 2007
    224
    OK, Thanks for the info :)
  5. cumesoftware
    Apr 27, 2007
    1,330
    11
    I'm not sure, but I think that in caps such as those, the can is connected to the negative pole of the capacitor.
