What's there to like about like?
Discussion in 'Feedback and Suggestions' started by jpanhalt, Jun 3, 2016.
  1. jpanhalt
    Thread Starter AAC Fanatic!
    Jan 18, 2008
    5,699
    909
    On Wednesday, June 1, at approximately 1 PM, I had 636 likes. By 4 o'clock that afternoon, I only had 631 likes.
    Why?
    John
  2. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Since members can like and unlike your posts, the simplest explanation would be that you somehow offended someone's sensibilities and in a fit of pique they removed several of their likes.
    If a member gets banned, do the likes they've placed on posts get removed?
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Your explanation is simple, and is what I thought initially, but it doesn't fit all the facts.
    John
  4. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Do you suspect a software bug?
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Yes. There are other possibilities, but a bug is hopefully the answer, and there is an easy work around for it, if true.
    John
  6. GopherT
    Nov 23, 2012
    6,300
    4,020
    I returns your likes.
  7. shortbus
    Sep 30, 2009
    4,086
    1,665
    I likes your returns. Your a nice guy.:)
    atferrari and GopherT like this.
  8. WBahn
    Mar 31, 2012
    18,079
    4,917
    What facts doesn't it fit? If someone removed five likes between the two times you checked, that would account for it.
    If a liked post of yours is deleted, then the likes go away too. This also applies to a thread containing such liked posts that is deleted.
  9. WBahn
    Mar 31, 2012
    18,079
    4,917
    No, the likes remain. But if the post that was liked is deleted, the likes are no longer counted.
    KJ6EAD likes this.
  10. jpanhalt
    Jan 18, 2008
    5,699
    909
    Here is the sequence of events:
    I made 4 posts to this thread: http://forum.allaboutcircuits.com/threads/1hz-brief-pulse-from-lmc555cmm.124409/#post-1002688 The TS originally "liked" most, if not all posts. So, I had 4 likes from him and notices thereof. A short time later, he removed the likes and, as expected, the likes were removed from my account. There is no notice given for that. Then, a few days later, the likes reappeared in the thread, but instead of receiving them back, I lost 4 more likes. Again no notice was given when the likes were re-posted. Why not? Moreover, in my "likes received" list, the likes show the original date, not the date they were re-posted.
    I went to the Xenforo forum and searched on like/unlike/like and there are discussions of it; however, I could not access them as I was not properly registered. From the titles of the posts, it seems there is some lack of clarity of what actually happens.
    Unfortunately, the tools available to members on AAC do not allow one to see "unlikes" nor to see to whom to whom one has given likes so I could run a test. I asked a moderator/administrator by PM to look into it and received no response, so I posted here.
    Sure, the evidence is circumstantial, but there is one hard fact. When the TS re-liked, there was no alert of that, and there was no bump in my number. Why not? As for the timing, I do not know the exact date of the re-like. I do know it was after the thread effectively ended (i.e., on May 27th) and on or before June 1st, yet the re-like shows as May 24 (i.e., as the original). Why? And finally, it would seem a simple matter for a moderator to check into those lost points. I have not received notice of posts of mine being deleted since May 24th.
    John
  11. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    The likes may have reduced by deleting posts from the forum.
    If you want to ask technical problems with the forum, better ask @jrap .
    He has programmed the looks of this forum and implemented a lot of features.
    Bertus
  12. WBahn
    Mar 31, 2012
    18,079
    4,917
    It might seem like a simple matter for a moderator to check into them, but it isn't. I have absolutely no way to do it. I'm not aware of ANY more capabilities that I have regarding ANY of the things you have mentioned relative to a regular member. I would expect an Administrator to have those capabilities -- though it might require installing add-ins or writing queries to do so.
  13. #12
    Nov 30, 2010
    16,663
    7,307
    I see your return and raise you a quote.
    GopherT likes this.
  14. ScottWang
    Aug 23, 2012
    4,924
    777
    You can check all the details for liked alerts from your account/Likes You've Received, every likes and dislike always has alerts, if you can see the like or dislike from forum, but you didn't get the alerts then it could be the bug of forum.
  15. WBahn
    Mar 31, 2012
    18,079
    4,917
    But I'm pretty sure that you still won't get an alert when a Like is removed.
  16. DickCappels
    Aug 21, 2008
    2,752
    665
    @WBahn, a moment ago I liked then unliked the post above. Did you received notifications of either or both?
  17. jpanhalt
    Jan 18, 2008
    5,699
    909
    Wrong.
    1) The re-likes had no alerts.
    2) The "un-like" (AAC doesn't have "dislikes") did not give an alert. On forums with dislikes, the dislikes may give alerts.
    Yes, I believe there is a bug in the forum.
    @DickCappels
    Not sure a test among moderators would be applicable, if it failed. There have been numerous instances in which moderators see things differently then members.
    The action that doesn't seem to work logically is the "re-like." It seems to work like an unlike, no notice, minus points, but the poster appears in your list of "likes received." At least that is what seems to have happened in the thread I linked to.
    John
  18. ScottWang
    Aug 23, 2012
    4,924
    777
    I pressed the like and unlike buttons, and try mine.
  19. ScottWang
    Aug 23, 2012
    4,924
    777
    Yes, you are right, I forgot to check the correct name.
    And I just pressed the like and unlike buttons once, now try mine.
  20. ScottWang
    Aug 23, 2012
    4,924
    777
    Dick, try mine.
