what's the wrong with my code?
Discussion in 'Programmer's Corner' started by moslem, Jul 15, 2010.
  1. moslem
    Dec 16, 2009
    20
    hello,
    my code is to read a file and inserting it to a list and type it to a nother file my problem is with files when opening it it already be opened but i reads no thing from the file and i don't know why?
    i want to know the reason.
    Thanks.
    my code:
    #include"ordering.h"
    using namespace std;
    int main()
    ordering A;
    ifstream in;
    bool flag;
    string line;
    in.open("C:\\infile.txt");
    while(! in.eof());
    {getline(in,line);
    A.inorder_insertion(line);
    in.close();
    ofstream out;
    out.open("C:\\outfile.txt");
    flag=A.inorder_first(line);
    while(flag){
    out<<line<<endl;
    flag=A.inorder_next(line);}
    out.close();
    return 0;
  2. davebee
    Oct 22, 2008
    539
    46
    Is this really what you want to do?
    while(! in.eof());
  3. moslem
    Dec 16, 2009
    20
    yes i want to read from file till it's end what the problem with that?
  4. Harrington
    Dec 19, 2009
    86
    hmmmm
    C is a strange langauge Its the most powerful of all langauges You can do anything with C / C++ What you tell it to do it will literally do It doesent ask questions like java or other compilers
    Try this
    Code ( (Unknown Language)):
    1.
    2. #include <sstream>
    3. #include <fstream>
    4. #include <vector>
    5. #include <iterator>
    6. #include <algorithm>
    7.
    8. using namespace std;
    9.
    10. void put_into_vector( ifstream& ifs, vector<int>& v )
    11. {
    12.   string s;
    13.   getline( ifs, s );
    14.   istringstream iss( s );
    15.   // not the fastest method ...
    16.   copy( istream_iterator<int>( iss ), istream_iterator<int>(), back_inserter( v ) );
    17. }
    18.
    19. int main()
    20. {
    21.   vector<int> line_1, line_2;
    22.
    23.   ifstream ifs( "data.txt" );
    24.
    25.   put_into_vector( ifs, line_1 );
    26.   put_into_vector( ifs, line_2 );
    27.
    28. }
    29.
  5. Harrington
    Dec 19, 2009
    86
    Put this another way Whats the difference between this
    1.
    2. # include "iostream.h"
    3.
    4.
    5. void main()
    6.
    7. {
    8.
    9.   int c = 4 ;
    10.
    11.  while( c=4)
    12.  {
    13.   cout << "Hello World " << endl ;  // whats the problem with this ??
    14.   c += 1 ; // increment c by 1
    15.
    16.  }
    17.
    18. }
    19.
    20.
    And this ??
    1.
    2. void main()
    3.
    4. {
    5.
    6.     int c = 4 ;
    7.
    8.      while( c==4)
    9.     {
    10.      cout << "Hello World " << endl ;  // whats the problem with this then ??
    11.      c+= 1 ; // increment c  by one
    12.
    13.      }
    14.
    15. }
    16.
    17.
    Whats your answer ?? Both are valid statements in C++ Both will compile Both will give you entirely different results
  6. Harrington
    Dec 19, 2009
    86
    Now lets see what happens if you do the same in java First Line of code
    that Ive given you
    Note the difference in the compilers reports
    It wont compile wont let you do it
    Code example
    1.
    2. import java.io.* ;
    3.
    4. public class HelloWorld {
    5.
    6.
    7.     public static void main (String Args[])
    8.     {
    9.
    10.         int c = 4 ;
    11.
    12.          while (c=4)
    13.          {
    14.              System.out.println("Hello World") ; // out Hellworld
    15.
    16.              c+= 1 ;
    17.
    18.          }
    19.
    20.
    21.     }
    22.
    23.
    The compiler reports the following
    Compiling 1 source file to
    HelloWorld.java:20: incompatible types
    found : int
    required: boolean
    while (c=4)
    1 error
    Do you see the big difference between C++ And Java
  7. Harrington
    Dec 19, 2009
    86
    So the question is Do you really want it to do that In other words "What are you telling this program to do ?? Good question isn't it ??
  8. eblc1388
    Nov 28, 2008
    1,542
    102
    Yes, it is a good question by davebee.
    He(or I think) simply means the semicolon at the end of the While statement, which shouldn't be there if user wants the code block immediately following it to be executed.
  9. Harrington
    Dec 19, 2009
    86
    Thank you L Chung I had a feeling someone else had worked this out
  10. davebee
    Oct 22, 2008
    539
    46
    That's right; I was trying to pass along a hint to what looked to me like a problem in hopes that moslem would work it out and gain some debugging skills...
  11. Durara
    Jul 27, 2010
    debugging skills growing by experiment
