what's the purpose of the zener, mosfet
Discussion in 'Homework Help' started by bug13, Aug 16, 2012.
  1. bug13
    Feb 13, 2012
    1,214
    38
    Hi
    I am just wondering what's the purpose of the zener between the s and g of the mosfet, a 2kHz signal is fed to the G.
    thanks
    Zhuhua
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The zener diode is there to protect the mosfet.
    It will probably be a 12 Volts zener, as a gate voltage higher as 15 Volts will damage the mosfet.
    Bertus
    bug13 likes this.
  3. bug13
    Feb 13, 2012
    1,214
    38
    so what would be the cause of the higher voltage? the signal fed to the mosfet should be 12v as swell, the whole circuit is power by 12v (other part of the circuit is not in the pic)
    Zhuhua
  4. praondevou
    Jul 9, 2011
    2,936
    489
    As bertus said, it's just an additional (maybe unnecessary protection (under normal circumstances)).
    VGSmax for this transistor is +-30V.
    bug13 likes this.
  5. Ron H
    Apr 14, 2005
    7,050
    657
  6. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Speakers are inductive loads and they can cause transiets that can destroy FETs.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Say what?!? Uh, No. While they have inductive properties it is very small compared to the total resistance. These are not relays, which do have substantial inductance.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Especially with a resistor in series, as in the schematic.
  9. steveb
    Jul 3, 2008
    2,433
    469
    Static discharge would be a concern. Also transients can happen.
    bug13 likes this.
