You don't need fancy materials - I've seen people get away with winding a blocking oscillator JT inductor round a nail.I want to make a joule thief, but I haven't been able to find a toroid bead yet.
Thanks, I understand that I can use a nail or a screw, but:The main use of a joule thief for me is efficiency, it will drive an LED with a voltage that would not work by itself.
You could use a nail or a screw to make an inductor, I have. It is not that finicky.
I'm not sure if I have a type of wire that will work for the coil. Must it be magnetic wire, or will insulated 22- or 28-gauge wire work?
I noticed that you wrapped twisted wire around the nail. Would I need to use two wires as well?Nearly any copper wire will work if you have enough turns. As Wendy said, the circuit is not finicky.
Sorry, I'm still not sure that I understand. Do you mean that I do need two wires, one coiled around the other? It looks like the wood core inductor on @DickCappels' page uses only one wire, but there's no circuit diagram for it.Think transformer. A small coil around a large coil.
A common way of making a blocking oscillator starts with one length of wire.Sorry, I'm still not sure that I understand. Do you mean that I do need two wires, one coiled around the other? It looks like the wood core inductor on @DickCappels' page uses only one wire, but there's no circuit diagram for it.
There are other ways.
Such as adding wire to a ready made inductor.
Its easier with large ones
As per my suggestion in post #23.
I have successfully built a Joule thief using a toroid from a line filter and I used thin plastic insulated wire in two colours. I save all depleted AA and AAA cells and use them with this circuit until the battery is depletedThere are other ways.
Its easier with large ones but Ive done it with a RF inductor (needs extra parts though).
Or using small HF transformers. RadioShack or Maplin dont have these and even real distributors dont always have a good selection but they do exist.
Its possible with some TOKO HF transformers too.
Still talking about the original unmodified Joule Thief, not the variant with 2 coils and a capacitor divider.
The nail circuit really is a bit creepy as iron has high losses starting at a few KHz. you may see very reduced battery life.
EMI Toroids are easy to buy and cheap in quantity but not worth the hassle ordering a single piece from a distributor. They normally expect $100 order minimum and consider that as "small", true some accept any small order with a shipping surcharge.
Im not mentioning my own sales on ebay here...
But really EMI toroids are common, still mass produced, and dont cost much.
Cores from PC mainboards arent really good for JT,
neither the ones used for common mode chokes (used in line filters).
I have made transformers with cores as small as 6mm but magnetic parameters must be suitable.
I tried building a joule thief circuit based on your post and @DickCappels' floor nail inductor, but it isn't working. Here's a picture of the breadboard:A common way of making a blocking oscillator starts with one length of wire.
Wind on about 15 - 20 turns for the collector, at the end of that winding you bring out a loop of wire and twist it to make a neat tapping, then wind on another 12 - 15 turns for the base (connected via a resistor). The loop that's twisted out for the tap is the +1.5V Vcc.
If you use enamelled copper wire - which some suppliers call; "magnet wire", its fairly easy to scrape off enough enamel at the end of the tap to tin some solder on it, the heat will peel more enamel off so you can make a sound solder joint.
You can use insulated hookup wire, but stripping the end of the loop can be fiddly - solid wire is slightly easier than stranded.
Though it may not be necessary, you might get better coupling.Oh, do I need to wind the secondary coil around the primary one? I probably didn't wind my inductor correctly.
by Jake Hertz
by Jake Hertz
by Duane Benson
by Jake Hertz
