what's the name of this switch
Discussion in 'General Electronics Chat' started by hemo200, Apr 24, 2008.
  1. hemo200
    Apr 23, 2008
    hey all
    I need to know what is the name of the switch, which is in the following picture and if possible the RS code for it.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's a momentary pushbutton switch.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    They're commonly known as a SPST tactile switch.
    Radio Shack does stock them, but you would not want to buy 12 of them at $3.99/each.
    http://www.radioshack.com/product/i...&cp=2032058.2032230.2032278&parentPage=family
    Mouser sells a very similar switch for $0.26 each:
    http://www.mouser.com/Search/ProductDetail.aspx?qs=fMKjfF2mFogxxxF7SUHlkQ==
    $3.12+ shipping vs $47.88 is pretty attractive.
    The lead spacing isn't quite right for standard 0.1" perfboard hole spacing, but you can make them fit if you're careful.
    As far as the design, you could make it more compact. Right now, you have:
    COM
    (unused)
    (com)
    (unused)
    5
    6
    ....etc...
    Instead, you could wire it as:
    COM
    (com)
    5
    6
    ...etc...
    Just an idea.
  5. hemo200
    Apr 23, 2008
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, it would - but why not use the multiplexed keyboard to simplify your wiring, and where you need the discrete signals use a demultiplexer IC?
  7. cherry886
    Apr 23, 2008
    This is Cherry from China, This is my first time to come here, I learned a lot. Thanks.
